[postgis-devel] Fwd: How to upload Korean PostGIS 2.0 manual topostgis.net?
George Silva
georger.silva at gmail.com
Tue Nov 19 16:34:03 PST 2013
If there are no objections, then I'll setup transifex for a opensource
project.
If anyone wants to comment or chime in, let me know in advance. I'll do
this on saturday.
On Tue, Nov 19, 2013 at 10:20 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> I have no problem using transifex.com
> the work here is (and always has been) in getting our doc build (and our
> gui build) to break down into chunks suitable for a translation system and
> to integrate with that system, not in setting up the system.
> P
> Paul Ramsey
> http://cleverelephant.ca
> http://postgis.net
> On Tuesday, November 19, 2013 at 4:18 PM, George Silva wrote:
> > Now the PostGIS team should decide if they need a separate server or
> they want to depend on transifex.
> > For me it's not trouble.
> > On Tue, Nov 19, 2013 at 9:59 PM, Daniel Kastl <daniel at georepublic.de(mailto:
> daniel at georepublic.de)> wrote:
> > > Hi George,
> > > Thank you for your offer!
> > > For pgRouting we would prefer to stay on Transifex.com (
> http://Transifex.com) website. Transifex is open source, so it allows us
> to setup our own server, just in case. But it's less maintenance work and
> doesn't cost for open projects. And there are lots of translators active on
> Transifex.com (http://Transifex.com), so it happens from time to time,
> that people join and contribute, who I have never met on the mailing list.
> I don't want to miss this opportunity.
> > > For pgRouting it was not difficult to configure Transifex as we used
> Sphinx for documentation without much custom hacks, and there are enough
> recipes available how to configure it. It took some time to learn how the
> publishing and then pulling the changes, but for the translators it's very
> easy to contribute, which is the big advantage in my opinion.
> > > We put together some scripts, which might be a bit Sphinx/pgRouting
> specific, but maybe they are helpful for others as well:
> > > https://github.com/pgRouting/pgrouting/tree/develop/tools/transifex
> > > And there is a translators guide in the pgRouting Wiki:
> > > https://github.com/pgRouting/pgrouting/wiki/Translation-Process
> > > https://github.com/pgRouting/pgrouting/wiki/Get-latest-translation
> > > Daniel
> > > On Wed, Nov 20, 2013 at 8:45 AM, George Silva <georger.silva at gmail.com(mailto:
> georger.silva at gmail.com)> wrote:
> > > > Hello everyone,
> > > > It would be awesome.
> > > > Our company can donate a server to setup transifex for PostGIS and
> other projects interested (pgRouting, for instance). For now it will be a
> small machine, but i think it will be enough.
> > > > I'll set it up this weekend (I can't do it before that).
> > > > Does anyone have a domain or subdomain that you'll want me to park
> this certain IP? For instance, i18n.postgis.net (http://i18n.postgis.net)?
> If there is interest I'll let you know the server IP once everything is
> setup.
> > > > On Tue, Nov 19, 2013 at 3:47 PM, Paul Ramsey <
> pramsey at cleverelephant.ca (mailto:pramsey at cleverelephant.ca)> wrote:
> > > > > IT would be so awesome to get a real translation effort going!
> > > > > Paul Ramsey
> > > > > http://postgis.net
> > > > > On Monday, November 18, 2013 at 8:09 PM, Paragon Corporation wrote:
> > > > > > BJ,
> > > > > > It's up and thanks very much for the hard work on this.
> > > > > > http://postgis.net/documentation/
> > > > > > George,
> > > > > > It's looking like transifex is the preferred choice for
> translation. Given that QGIS, pgRouting already use it seems like there is
> a knowledge base and group of translators to tap into already and we can
> just use the transifex hosting for OS projects.
> > > > > > Are you still interested in spearheading this effort?
> > > > > > Thanks,
> > > > > > Regina
> > > > > > From: postgis-devel-bounces at lists.osgeo.org (mailto:
> postgis-devel-bounces at lists.osgeo.org) [mailto:
> postgis-devel-bounces at lists.osgeo.org] On Behalf Of BJ Jang
> > > > > > Sent: Monday, November 18, 2013 9:54 PM
> > > > > > To: postgis-devel at lists.osgeo.org (mailto:
> postgis-devel at lists.osgeo.org) (mailto:postgis-devel at lists.osgeo.org)
> > > > > > Subject: [postgis-devel] Fwd: How to upload Korean PostGIS 2.0
> manual topostgis.net (http://topostgis.net) (http://topostgis.net)?
> > > > > > Dear Regina and Paul.
> > > > > > Thank you for your kindness.
> > > > > > Html job is expected to be a very long job.
> > > > > > So, I will send PDF first. Please upload to
> http://postgis.net/documentation/.
> > > > > > In the case of QGIS, In the past, using File & Git, but now
> Transifex is being used[1].
> > > > > > I think Transifex is more comfortable and easy to co-work.
> > > > > > Regards
> > > > > > BJ Jang.
> > > > > > [1] https://www.transifex.com/projects/p/qgis-documentation/
> > > > > > 2013/11/19 Paragon Corporation <lr at pcorp.us (mailto:lr at pcorp.us)
> (mailto:lr at pcorp.us)>
> > > > > > > BJ and Paul,
> > > > > > > I've moved this discussion to dev list. Several people have
> asked for a more
> > > > > > > structured approach.
> > > > > > > As an interim fix I guess we can setup an ftp folder (or even
> simpler just
> > > > > > > link to foreign translations), but that's not that elegant
> maintenance wise.
> > > > > > > I think some thoughts about a more permanent solution would be
> using pootle
> > > > > > > or transifex. I see pgRouting uses transifex and George Silva
> wanted to
> > > > > > > setup a transifex as well.
> > > > > > > Any thoughts anybody
> > > > > > > Thanks,
> > > > > > > Regina
> > > > > > > http://www.postgis.us
> > > > > > > http://postgis.net
> > > > > > > -----Original Message-----
> > > > > > > From: Paul Ramsey [mailto:pramsey at boundlessgeo.com]
> > > > > > > Sent: Monday, November 18, 2013 12:47 PM
> > > > > > > To: BJ Jang
> > > > > > > Cc: Regina Obe
> > > > > > > Subject: Re: How to upload Korean PostGIS 2.0 manual to
> postgis.net (http://postgis.net) (http://postgis.net)?
> > > > > > > Hi BJ,
> > > > > > > I'm forwarding this to Regina Obe, who handles our
> documentation work. I'm
> > > > > > > sure we can find some way to get multi-lingual on the site.
> > > > > > > P.
> > > > > > > Paul Ramsey | Boundless
> > > > > > > http://boundlessgeo.com/support/postgis
> > > > > > > 2508850632 (tel:2508850632) | @pwramsey
> > > > > > > On Monday, November 18, 2013 at 2:43 AM, BJ Jang wrote:
> > > > > > > > Dear Paul Ramsey.
> > > > > > > > Hi. I'm BJ Jang, translate coordinator of OSGeo Korean
> chapter.
> > > > > > > > We (OSGeo Korean chapter) have just finished the translation
> of
> > > > > > > > PostGIS 2.0 Manual. (unfortunately not for 2.1) Publish to
> paper book[1]
> > > > > > > and distributed freely at the FOSS4G Korea event[2].
> > > > > > > > And, make it to PDF file, will be distributed freely at
> osgeo.kr (http://osgeo.kr) (http://osgeo.kr)
> > > > > > > (http://osgeo.kr) site.
> > > > > > > > I want upload it postgis.net/documentation/ (
> http://postgis.net/documentation/) (http://postgis.net/documentation/)
> > > > > > > (http://postgis.net/documentation/) site too.
> > > > > > > > And, I want to make PostGIS 2.1 HTML Korean version.
> > > > > > > > Please let me know, how I can do these things.
> > > > > > > > Regards
> > > > > > > > BJ Jang.
> > > > > > > > [1]
> https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn2/v/r270/p480x480
> /1422697_10202432727079433_1204862728_n.jpg?oh=d4f801c60c8b013186e44e3
> c4d26d01f&oe=528BAD2B&__gda__=1384977666_d24dd696d10d31074fa7679dce352
> > > > > > > > b00
> > > > > > > > [2] http://osgeo.kr/140
> > > > > > > > Open Source GIS Technical Manager / e-Cartographer BJ Jang
> > > > > > > > Gaia3D Inc,
> > > > > > BJ Jang
> > > > > > Gaia3D Inc,
> > > > > > BJ Jang
> > > > > > Gaia3D Inc,
> > > > > > _______________________________________________
> > > > > > postgis-devel mailing list
> > > > > > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> > > > George R. C. Silva
> > > > SIGMA Consultoria
> > > > http://www.consultoriasigma.com.br/
> > > > postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> > > Georepublic UG & Georepublic Japan
> > > eMail: daniel.kastl at georepublic.de (mailto:daniel.kastl at georepublic.de
> > > Web: http://georepublic.de (http://georepublic.de/)
> > George R. C. Silva
> > SIGMA Consultoria
George R. C. Silva
SIGMA Consultoria
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131119/2ff53c4a/attachment.html>
