[postgis-devel] ALTER EXTENSION postgis UPGRADE to '2.1.1'
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 15 13:59:43 PDT 2013
The function ends up in a file named thusly:
postgis_upgrade_20_21.sql
So, we've got a "make sure it isn't 1.X" check, in a script which is
clearly named to allow for upgrades from 2.0 to 2.1. I think it's safe
to remove it entirely.
P
On Tue, Sep 24, 2013 at 1:55 AM, Sandro Santilli <strk at keybit.net> wrote:
> Can that call be _only_ removed from EXTENSION scripts ?
> I also pre-date extensions and not sure I want to go there before
> those 10 years ;)
> --strk;
> On Mon, Sep 23, 2013 at 01:29:42PM -0700, Paul Ramsey wrote:
>> This has been failing for people using packages to manage their
>> postgis, because upgrading their postgis2 package is removing the old
>> postgis-2.0.so and installing a postgis-2.1.so file.
>> I isolated the problem while on the plane, it's the temporary
>> postgis_major_version_check function, which calls a library function
>> during installation. I think it'll take a half day of careful thinking
>> and testing to get a fix that both works on existing installations and
>> also does the right thing, which I think is to get rid of that routine
>> entirely. It's very old and pre-dates extensions, and we don't have an
>> upgrade_15_21 script anyways. We can add a replacement in 10 years
>> when we do 3.0
>> P.
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
