[postgis-devel] PAGC Address Standardizer some thoughts on howtoorganize
Stephen Woodbridge woodbri at swoodbridge.com
Wed Aug 6 10:55:00 PDT 2014
Hi Regina,
I'm fine with this.
I'm ok, with not supporting 9.0
So when all is said and done we will be able to:
CREATE EXTENSION address_standardizer;
Are you still planning to have the lex, gaz and rules data installable
via a .sql file so people can load and modify the tables as they might need?
When you install postgis_tiger_geocoder that will install the
address_standardizer and it's own private lex, gaz, and rules tables. Is
this correct? Or will you just postgis_tiger_geocoder dependent on the
address_standardizer extension?
Thanks,
   -Steve
On 8/6/2014 12:03 AM, Paragon Corporation wrote:
>>>>> 1) Create folder in extensions of our repo and move the
>>>> address_standardizer extension files to their I'd still like it to
>>>> be able to be built separately if people wish (similar to how we
>>>> have liblwgeom I think) and my only reservation with breaking out
>>>> like this is that it makes it less compact.
>> I would defer to strk on this, but can we use a symlink to get the
>> file to appear in two places under svn?
>> Let's stay away from symlinks - they don't behave well under windows.  I
> think for now we'll Just leave the extension files wher they are and decide
> what to do later.
>> Perhaps just copy the control files as part of our extension make scripts.
>> I was the one who started the extension folder primarily because when I
> was formulating the extension install Process, it was easier not to affect
> the rest of the code base while I was fleshing things out.
>> That said the only issue is the documentation auto comments generation
> that I would like address_standardizer to Have similar to the other
> extensions we have.  As well as the versioning plumming that all postgis
> extensions share.
>> Let's see how things go keeping things where they are unless someone has a
>> better idea.
> Just an update on this thread.  In working thru the logistics of folding in
> address_standardizer into our configure scripts, I've decided to just move
> all of address_standardizer code into the extensions folder and out of
> extras
> So instead of it being in
> Extras\address_standardizer
> It will be ONLY be in
> extensions\address_standardizer
> The reason for this is after I was fiddling with the make file to make it
> use the same machinery as the rest of our code base and our extension
> versioning there was really nothing left in the makefile.
> This avoids the whole whether to copy stuff to extensions or symlink.
> Also in PostGIS 2.2, we no longer support PostgreSQL 9.0.  That said, there
> is no reason why anyone should be installing address_standardizer without
> using CREATE EXTENSION
> Let me know if anyone has objection to this before I move forward with this
> change.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
