[postgis-devel] Entry point to a "create index" query
mohit kumar
mohitkharb at gmail.com
Tue Aug 12 01:48:23 PDT 2014
Hi Strk,
spgist has a different datastructures for every support function so making
it difficult to use a geometry datatype.
using geometry as the datatype is also not helping.
in every case I am getting stuck in the very first line of the the code.
Regards,
Mohit
On Tue, Aug 12, 2014 at 2:00 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Tue, Aug 12, 2014 at 01:43:39PM +0530, mohit kumar wrote:
> > Hi all,
> > I am still stuck at the implemantation of sp-gist on geometry in postgis
> as
> > the structures for spgist support functions are not supporting geometry
> > datatypes (box2df in my case).
> Spgist support functions are those you register yourself in the OPERATOR
> CLASS creation. What does it mean they don't support geometry datatypes ?
> And why is it a box2df if we already found out some weeks ago that spgist
> does not support an index storage type different from the target type ?
> > spgConfigOut is not taking POINTOID or VOIDOID as a valid datatype and
> > giving a segmentation fault.
> > Also by printing spgConfingOut, it prints integer value of 10 not a
> memory
> > address which a pointer should give.
> If you pass "%d" as the format string, the generated code will print
> an integer whatever you pass as an argument. You want to use "%p" to
> print a memory address. See `man 3 printf`.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Mohit Kumar
+91-970-3840-175
Lab For Spatial Informatics
International Institute of Information Technology
Hyderabad, India
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140812/a78a2767/attachment.html>
