[postgis-devel] Death to PGXS
Greg Troxel
gdt at ir.bbn.com
Sat Dec 6 10:24:25 PST 2014
My $0.02 as the packager for pkgsrc (NetBSD, and also runs on Illumos):
More terribly, I found a postgresql93 package on freebsd that was
compiled in an environment apparently without perl, so PGXS defines
$(PERL) as "/bin/sh
/usr/local/lib/postgresql/pgxs/src/makefiles/../../config/missing”,
which doesn’t really help our build at all.
I can see why they did that; when packaging one wants to omit
dependencies. postgresql93 probably runs fine without perl, as long as
you don't try to use the makefiles. So, it's really that postgresql
has a hard dependency on perl and it's broken without it, and the
FreeBSD port should probably be fixed. But the pkgsrc package has the
same problem (perl is a dependency for -plperl), and postgis builds in
the pkgsrc environment.
The issue of forcing the compiler and flags seems messier; forcing
compiler to something non-free certainly seems like a problem.
If postgis were to ditch PGXS (which seems like a reasonable concept),
it would have to reinvent all of that, which to me would seem like not
only the usual auto* but libtool.
Presumably pg_config should be expanded to handle anything postgis needs
that isn't alreayd there. As a workaround, a makefile that includes
pgxs could be invoked to spit out a variable, letting postgis use info
From pgxs land without buying into the build system.
As a packager, I'm really only interested in the case where both pgsql
and postgis use the same --prefix. It has always seemed that addons of
any sort get awkward when there are different prefixes.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20141206/0dc09549/attachment.sig>
