[postgis-devel] Death to PGXS
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Sun Dec 7 09:15:19 PST 2014
On 06/12/14 18:24, Greg Troxel wrote:
> My $0.02 as the packager for pkgsrc (NetBSD, and also runs on Illumos):
> More terribly, I found a postgresql93 package on freebsd that was
> compiled in an environment apparently without perl, so PGXS defines
> $(PERL) as "/bin/sh
> /usr/local/lib/postgresql/pgxs/src/makefiles/../../config/missing”,
> which doesn’t really help our build at all.
> I can see why they did that; when packaging one wants to omit
> dependencies. postgresql93 probably runs fine without perl, as long as
> you don't try to use the makefiles. So, it's really that postgresql
> has a hard dependency on perl and it's broken without it, and the
> FreeBSD port should probably be fixed. But the pkgsrc package has the
> same problem (perl is a dependency for -plperl), and postgis builds in
> the pkgsrc environment.
FWIW Debian do a slightly interesting thing from memory which is where
they supplied a "cut down" version of the PostgreSQL Makefile and
pg_config with a lot of things missing. Installing the postgresql-dev
pacakge then brings in the "complete" Makefile and pg_config (plus other
build-time dependencies) which can be used to build extensions/modules
as normal.
The slightly annoying part here is that it's difficult to tell the
difference from a "cut down" pg_config and a "development" pg_config as
normally the existence of pg_config itself should indicate that a full
build environment is available...
ATB,
Mark.
