[postgis-devel] Postgis topology creation - O(n-squared)? - creates problems with large datasets.
Sandro Santilli
strk at keybit.net
Mon Jan 13 13:14:43 PST 2014
On Mon, Jan 13, 2014 at 10:11:48PM +0100, Sandro Santilli wrote:
> These are the function that are run for insertion of a _single_ polygon when
> the topology already contains 165000 faces.
> -- Ordered by "self_time":
> strk=# select * from pg_stat_user_functions order by self_time desc;
> funcid | schemaname | funcname | calls | total_time | self_time
> 62973 | topology | _st_addfacesplit | 2 | 424.356 | 192.07
> 52356 | public | st_lineinterpolatepoint | 165013 | 136.911 | 136.911
> 52097 | public | geometry_overlaps | 165015 | 92.684 | 92.684
> 54503 | topology | st_addedgemodface | 1 | 438.418 | 13.539
> 54508 | topology | st_addisonode | 1 | 7.39 | 7.359
> 54491 | topology | getringedges | 2 | 2.552 | 2.552
> 54533 | topology | topogeo_addlinestring | 1 | 450.942 | 2.385
> 54534 | topology | topogeo_addpoint | 2 | 9.287 | 1.837
> Interesting enough, "geometry_overlaps" and "st_lineinterpolatepoint" are called
> once for each and every already-loaded geometry, which suggests there's indeed a
> problem with index usage. The "geometry_overlaps" function is the one that
> implements operator&&, supposedly an index user!
Another interesting information is that the _second_time_ you pass the same
input to TopoGeo_addPolygon, "geometry_overlaps" gets called 9 times only,
which is more like the expected number out of an index filter...
--strk;
() ASCII ribbon campaign - against html e-mail
/\ http://www.asciiribbon.org - against proprietary attachments
