On Mon, Jan 13, 2014 at 10:14:43PM +0100, Sandro Santilli wrote:
> On Mon, Jan 13, 2014 at 10:11:48PM +0100, Sandro Santilli wrote:
> > These are the function that are run for insertion of a _single_ polygon when
> > the topology already contains 165000 faces.
> > -- Ordered by "self_time":
> > strk=# select * from pg_stat_user_functions order by self_time desc;
> > funcid | schemaname | funcname | calls | total_time | self_time
> > 62973 | topology | _st_addfacesplit | 2 | 424.356 | 192.07
> > 52356 | public | st_lineinterpolatepoint | 165013 | 136.911 | 136.911
> > 52097 | public | geometry_overlaps | 165015 | 92.684 | 92.684
> > 54503 | topology | st_addedgemodface | 1 | 438.418 | 13.539
> > 54508 | topology | st_addisonode | 1 | 7.39 | 7.359
> > 54491 | topology | getringedges | 2 | 2.552 | 2.552
> > 54533 | topology | topogeo_addlinestring | 1 | 450.942 | 2.385
> > 54534 | topology | topogeo_addpoint | 2 | 9.287 | 1.837
> > Interesting enough, "geometry_overlaps" and "st_lineinterpolatepoint" are called
> > once for each and every already-loaded geometry, which suggests there's indeed a
> > problem with index usage. The "geometry_overlaps" function is the one that
> > implements operator&&, supposedly an index user!
> Another interesting information is that the _second_time_ you pass the same
> input to TopoGeo_addPolygon, "geometry_overlaps" gets called 9 times only,
> which is more like the expected number out of an index filter...
I've found the culprit!
It's a query in topology._ST_AddFaceSplit that fails to make use of the index
by checking for overlap between a literal and a function over the indexed
geometry, in this form:
WHERE ST_Contains('...'::geometry, ST_LineInterpolatePoint(geom, 0.2));
For the index to be effective the query should first check overlap with whole
geometry and then containment.
Ticketed here: http://trac.osgeo.org/postgis/ticket/2610
--strk;
() ASCII ribbon campaign - against html e-mail
/\ http://www.asciiribbon.org - against proprietary attachments
