[postgis-devel] Polyhedral Surface / Polyhedron /TINS
Oliver Courtin olivier.courtin at oslandia.com
Fri Jul 11 00:14:07 PDT 2014
Le 11 juil. 2014 à 08:19, Paragon Corporation a écrit :
Regina,
> Do we have a function for setting that bit or is it simply computed it if
> determines the surface is closed?
For now there's not way to set/get this bit from userland,
ant it's current internal usage is dedicated to SFCGAL stuff.
But you're right we could imagine accessors to this SOLID bit,
> I can see cases where people would have a closed surfce but would not want
> it treated as a volume. (similar to closed linestring / polygon)
Could you give us examples about this ?
> Version 1.2.1 I see they do indeed have Polyhedron WKT on LXI (p. 61)
> Polyhedron Z
> ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
> ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)),
> ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),
> ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
> ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),
> ((0 0 1, 1 0 1, 1 1 1, 0 1 1. 0 0 1))
> Though oddly on  p (63)
> Where they give the Integer codes for geometric types, the PolyHedron seen
> earlier seems to be mysteriously not present.
Yeah looks definitely like a typo, (Polyhedron instead of PolyhedralSurface in p61)
as the related BNF in LIX refer to PolyhedralSurface,
and PolyhedrelSurface is also use for the integer codes in LXIII and LXIV.
> Which makes me wonder if the earlier WKT was a mistake or the rest of the
> doc was not updted to reflect this new type.
> I ask because Leo was asking why we don't have a Polyhedron type.
We have somehow, it's a closed PolyhedralSurface
O.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140711/f557fa37/attachment.html>
