[postgis-devel] Setting raster constraint: spatial extent
Bborie Park
dustymugs at gmail.com
Wed Jul 23 13:06:22 PDT 2014
You can safely not have the extent constraint in place. The limitation has
been removed in 2.2 where we changed how the max extent is computed.
-bborie
On Wed, Jul 23, 2014 at 12:45 PM, David Haynes II <dahaynes at umn.edu> wrote:
> Hello,
> I have posted this question on the PostGIS user group unsuccessfully and I
> am hoping this question can be answered by this forum. The research project
> I am working uses rasters with a world geographic extent. Often we find
> that when downloading the data the merged raster tiles extend beyond the
> defined geographic boundaries. For example, one landcover dataset
> (Globcover) has a geographic extent of
> -180.0013888888888971,-64.9986111111111171 :
> 179.9986111111111029,90.0013888888888829. It goes beyond the coordinate
> system bounds by approximately half a cell in the north west quadrant. This
> causes it fail when using raster2pgsql for ingest. Specifically applying
> the raster extent constraint on the built table causes it to fail.
> After much trial and error we can successfully ingest rasters by using
> gdalwarp to crop the raster to the bouding coordinates (-180 90, 180 -90).
> However the initial issue has returned to us because we are trying to use
> MODIS data in its native projection (Sinusoidal). Even when cropped to the
> appropriate bounding area the raster still fails on ingest. A solution was
> to adjust the raster2pgsql script to use the "-x" parameter which drops the
> spatial extent on ingest.
> Now datasets are loading into our system. However we tried to go back and
> set the geographic extent after of the raster were successfully generated,
> and in doing that we have run into the same problem. We are unable set the
> spatial extent of the MODIS data.
> SELECT AddRasterConstraints('gis_rasters'::name, 'modis_IGBP_mask'::name,
> 'rast'::name, 'extent');
> NOTICE: Adding maximum extent constraint
> NOTICE: Unable to get the extent of the raster column. Attempting memory
> efficient (slower) approach
> CONTEXT: PL/pgSQL function addrasterconstraints(name,name,name,text[])
> line 104 at assignment
> NOTICE: Still unable to get the extent of the raster column. Cannot add
> extent constraint
> WARNING: Unable to add constraint: 'extent'. Skipping
> ERROR: None of the constraints specified could be added. Is the schema
> name, table name or column name incorrect?
> The subfunction also returns false
> SELECT _add_raster_constraint_extent('gis_rasters'::name,
> 'modis_IGBP_mask'::name, 'rast'::name) FROm gis_rasters.modis_IGBP_mask
> Yet, this function works and returns the bounding coordinates when using
> ST_AsText()
> SELECT ST_ConvexHull(ST_Collect(ST_ConvexHull(rast))) FROM
> I have read through this ticket, but this seemed to be solved with a new
> update. http://trac.osgeo.org/postgis/ticket/2050
> Any help would be appreciated.
> David Haynes, Ph.D.
> Research Associate Terra Populous
> Minnesota Population Center
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140723/092635f1/attachment.html>
