[postgis-devel] Regarding Sp-gist implementation in postgis]
mohit kumar
mohitkharb at gmail.com
Mon Jul 28 05:19:47 PDT 2014
Reseting the conf file also gives the same output.
The restored configuration file is as http://pastebin.com/HA5ujeXT
Also, in which file the debugging prints need to be inserted? adding prints
in postgis/sp_gist.c are not working. DO they need to be inserted in
postgis.sql.in file?
Regards,
On Mon, Jul 28, 2014 at 4:23 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Jul 28, 2014 at 04:05:14PM +0530, mohit kumar wrote:
> > On 25 Jul 2014 13:13, "Sandro Santilli" <strk at keybit.net> wrote:
> > > On Fri, Jul 25, 2014 at 08:35:08AM +0530, mohit kumar wrote:
> > > > file(/usr/local/pgsql/data/postgresql.conf) are pasted at
> > > > http://pastebin.com/eaX383cw.
> > > The paths for "hba_file" and "ident_file" and "data_directory" all seem
> > > to be relative, so would resolve based on where you are when you start
> > > postgres. As you're starting it from ~/builds/source/postgis, I dubt
> > > you have ~/builds/source/postgis/ConfigDir, which would explain the
> error.
> > The error is coming even after removing the path for hba_file and
> > ident_file.
> See if there are other relative paths, paste new config again.
> Reset the config to default as last resort.
> Try also another path if this one (valgrind) is too hard for you:
> add debugging prints into the code to see which parts of the code
> are executed and which not.
> Try more things, try harder.
> --strk;
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
Mohit Kumar
+91-970-3840-175
Lab For Spatial Informatics
International Institute of Information Technology
Hyderabad, India
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140728/4e8d273a/attachment.html>
