[postgis-devel] topology : new index on node table
Rémi Cura
remi.cura at gmail.com
Wed Jul 30 03:36:17 PDT 2014
OK,
is it the timing with
CREATE INDEX ON node (containing_face);
OR is it without index?
Maybe a little vacuum analyze would help?
Cheers,
Rémi-C
2014-07-30 12:24 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> On Wed, Jul 30, 2014 at 12:09:05PM +0200, Rémi Cura wrote:
> > The ticket :
> > http://trac.osgeo.org/postgis/ticket/2860
> > If fitting in memory, I would expect the 160k geom of the benchmark to be
> > imported in less than 30 sec in grass, cgal and geos.
> Sum of memory size used to hold those 160k geometries in PostGIS memory
> is 26,592,360 (~26MB).
> > 300 sec for Postgis Topology batch mode would be a good goal (reachable
> and
> > nice achievement).
> Current best time (in that table) was 4984 secs (~2h20m)
> Still, we don't know exactly how much time went in triggers checking,
> how much in disk writing, how much in toasting/detoasting values etc.
> Speaking of which, another postgresql-level optimization that could
> be taken at population time could be setting the storage type, and
> setting the fill factor for tables should also make a difference.
> A lot to play with, having the time...
> Unfortunately running the population query for 5000 geometries right
> now gives me a longer time than I was getting back when I took the
> times for that test, and I'm not sure why. Maybe it's because I enabled
> gathering statistics about the called user functions, or because I changed
> some parameters about available memory work memory and such. I suspect
> those configurations change a lot the experience.
> Anyway, having stats on, will dump here the ones for loading 5000
> geometries
> from that dataset (ordered by gid):
> strk=# select * from pg_stat_user_functions order by total_time desc
> limit 10;
> funcid | schemaname | funcname | calls | total_time |
> self_time
> 54535 | topology | topogeo_addpolygon | 5000 | 55761.337 |
> 1369.537
> 54533 | topology | topogeo_addlinestring | 5004 | 48302.105 |
> 4038.88
> 54503 | topology | st_addedgemodface | 5004 | 33837.97 |
> 10328.094
> 62973 | topology | _st_addfacesplit | 10008 | 22461.719 |
> 17372.12
> 54534 | topology | topogeo_addpoint | 10008 | 9712.522 |
> 3570.827
> 54508 | topology | st_addisonode | 5004 | 6032.572 |
> 4861.636
> 54491 | topology | getringedges | 10008 | 4876.065 |
> 4876.065
> 54514 | topology | st_getfacegeometry | 11921 | 4674.631 |
> 3712.201
> 52455 | public | st_pointonsurface | 9591 | 1267.424 |
> 1267.424
> 52275 | public | st_buildarea | 11921 | 962.43 |
> 962.43
> (10 rows)
> You'll note that _ST_AddFaceSplit is called 10008 times, and at every
> call the number of points should be at least 1 more than the previous,
> with last call finding ~5000 nodes in the table.
> For the record, my current timing for loading those 5000 rows is 55822.181
> ms
> whereas my last best was 36134.786 ms (just to get an idea about how much
> database configuration could change times, as I think the machine was
> really the same).
> --strk;
> > 2014-07-30 11:56 GMT+02:00 Rémi Cura <remi.cura at gmail.com>:
> > > Almost a 10x factor, really nice !
> > > Cheers,
> > > Rémi-C
> > > 2014-07-30 11:38 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> > > On Wed, Jul 30, 2014 at 11:29:00AM +0200, Sandro Santilli wrote:
> > >> > There's a reference dataset produced some time ago by a user who
> > >> resulted
> > >> > in a fix making topology creation much faster:
> http://lists.osgeo.org/pipermail/postgis-devel/2014-January/024078.html
> > >> > I still have a couple of diagrams showing population time
> before/after
> > >> > that are waiting for a blog post that I never find the time to
> write...
> > >> Just a sneak preview of the blog post that might never be written
> > >> Queries:
> > >> SELECT ST_CreateTopoGeo('million_poly_topo1', ST_Collect(geom))
> > >> FROM ( SELECT geom from million_poly_topo1 order by gid limit
> 160000) as
> > >> f;
> > >> SELECT TopoGeo_addPolygon('million_poly_topo1', ST_GeometryN(geom,1))
> 160000) as
> > >> f;
> > >> Output topology has:
> > >> 160167 nodes, 160167 edges, 160167 faces
> > >> Times:
> > >> a: before starting
> > >> b: Ensure face splitting algorithm uses the edge index (#2610)
> > >> c: Drop all calls to geometry::text during topology population
> (#2616)
> > >> ST_CreateTopoGeo TopoGeo_addPolygon
> > >> a | 38352283.535 | 38375126.950 |
> > >> b | 12088554.776 | 9644736.277 |
> > >> c | 11963757.923 | 4984225.402 |
> > >> I've a table with more numbers, with limits from 5000 to 160000.
> > >> The index change would make another configuration (d, I guess).
> > >> Please please please file the ticket, maybe referencing this thread
> > >> and #2610 and #2616 as I'd really love to grow the optimizations
> further
> > >> --strk;
> > >> _______________________________________________
> > >> postgis-devel mailing list
> > >> postgis-devel at lists.osgeo.org
> > >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140730/3e89fca5/attachment.html>
