[postgis-devel] build issues on the git source of postgis.
Sandro Santilli
strk at keybit.net
Fri Jun 27 08:41:44 PDT 2014
Mohit, did you succeed ?
I'm starving for a status update :)
--strk;
On Fri, Jun 27, 2014 at 10:26:31AM +0200, Sandro Santilli wrote:
> On Fri, Jun 27, 2014 at 01:26:51PM +0530, mohit kumar wrote:
> > thanks strk,
> > the issue was resolved after merging and then changing the permissions.
> > Now the code is built and installed.
> > Strk, now how to test the build?
> make check
> ... as written in README.postgis, under the TESTING section
> You might have troubles connecting to the database, so make sure
> to set appropriate environment variables to be "superuser" on
> the database you'll connect to, like:
> PGUSER=postgres PGPASSWORD=guess make check
> --strk;
