[postgis-devel] build issues on the git source of postgis.
mohit kumar
mohitkharb at gmail.com
Fri Jun 27 10:18:29 PDT 2014
Hi strk,
I am using box2df as the storage for spgist indexes but and error is coming
while testing.
*ERROR: storage type cannot be different from data type for access method
"spgist"*
I searched a lot for the data type for spgist but didnt find it.
Regards,
Mohit
On Fri, Jun 27, 2014 at 9:11 PM, Sandro Santilli <strk at keybit.net> wrote:
> Mohit, did you succeed ?
> I'm starving for a status update :)
> --strk;
> On Fri, Jun 27, 2014 at 10:26:31AM +0200, Sandro Santilli wrote:
> > On Fri, Jun 27, 2014 at 01:26:51PM +0530, mohit kumar wrote:
> > > thanks strk,
> > > the issue was resolved after merging and then changing the permissions.
> > > Now the code is built and installed.
> > > Strk, now how to test the build?
> > make check
> > ... as written in README.postgis, under the TESTING section
> > You might have troubles connecting to the database, so make sure
> > to set appropriate environment variables to be "superuser" on
> > the database you'll connect to, like:
> > PGUSER=postgres PGPASSWORD=guess make check
> > --strk;
Mohit Kumar
+91-970-3840-175
Lab For Spatial Informatics
International Institute of Information Technology
Hyderabad, India
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140627/5ed74038/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140627/5ed74038/attachment.obj>
