[postgis-devel] upgrading to 2.2.0dev from 2.1
Rémi Cura
remi.cura at gmail.com
Fri Mar 7 11:08:47 PST 2014
About gdal : a 'sudo ldconfig', and now postgis_full_version is no more
mistaken.
I still have issue about postgres update script.
Shall I manually create the update script from 2.1 to 2.2 by fusing the
rt_postgis--2.1--2.2 , postgis .. ??
Thanks,
Cheers,
Rémi-C
2014-03-07 20:01 GMT+01:00 Rémi Cura <remi.cura at gmail.com>:
> Hey List,
> I downloaded and compiled the latest postgis version (from git).
> Everything runs smootlhy (new dependency for bison ?).
> Butmake install is not doing what it should.
> it creates the 'postgresql/9.3/contrib/postgis-2.2 folder' and file it
> with the stuff,
> but it doesn't create the files in 'postgresql/9.3/extension'
> such as postgis--2.2.0dev.sql, postgis--2.1-2.2.sql, and so.
> I created a postgis--2.2.0dev.sql by fusionning postgis.sql,
> rt_postgis.sql, spatial_ref_sys.sql,and changed the 'postgis.control'
> manually
> so I was able to add to a fresh database 'CREATE EXTENSION postgis VERSION
> '2.2.0dev'.
> Yet the version of GDAL is still the old one (according to postgis full
> version)
> In ./configure the correct version of gdal was recognized (1.11)
> Am I missing something?
> Thanks,
> Rémi-C
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140307/e1b82282/attachment.html>
