[postgis-devel] Pstgis raster ST_SetValues crashes server, or is it GDAL?
Bborie Park
dustymugs at gmail.com
Mon Mar 10 11:51:31 PDT 2014
Can't say for certain. ST_SetValues() itself doesn't use GDAL but the
geometry in geomval would be rasterized using GDAL. Can you isolate the
geometry causing the crash?
-bborie
On Mon, Mar 10, 2014 at 10:50 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey List,
> I encountered another annoying problem :
> I can reproduce it 100%, but I failed to produce an isolated test case.
> Problem occurs when using the ST_SetValues function to populate a freshly
> created raster band. It works the first time, then crashes the server (see
> stack, log only says : segfault)
> Strange point is : It is a plpgsql I wrote wrapping st_setvalues that
> crashes, and the same code doesn't crash outside a plpgsql function.
> Somebody would have any idea about that?
> Cheers,
> Rémi-C
> #0 0xb7216424 in __kernel_vsyscall ()
> #1 0xb6b811df in raise () from /lib/i386-linux-gnu/libc.so.6
> #2 0xb6b84825 in abort () from /lib/i386-linux-gnu/libc.so.6
> #3 0x7355279f in CPLEmergencyError (pszMessage=0x73993800
> "CPLGetTLSList(): pthread_setspecific() failed!") at cpl_error.cpp:314
> #4 0x7355f8e6 in CPLGetTLSList () at cpl_multiproc.cpp:1582
> #5 CPLGetTLSList () at cpl_multiproc.cpp:1563
> #6 0x73560358 in CPLGetTLS (nIndex=5) at cpl_multiproc.cpp:1598
> #7 0x735527b6 in CPLEmergencyError (pszMessage=0x73993800
> "CPLGetTLSList(): pthread_setspecific() failed!") at cpl_error.cpp:298
> #8 0x7355f8e6 in CPLGetTLSList () at cpl_multiproc.cpp:1582
> #9 CPLGetTLSList () at cpl_multiproc.cpp:1563
> #10 0x73560358 in CPLGetTLS (nIndex=14) at cpl_multiproc.cpp:1598
> #11 0x7354fa62 in CPLGetConfigOption (pszKey=0x73992681
> "GDAL_DISABLE_CPLLOCALEC", pszDefault=0x739bb70d "NO") at cpl_conv.cpp:1552
> #12 0x73550f58 in CPLLocaleC::CPLLocaleC (this=0xbfbdddcc) at
> cpl_conv.cpp:2405
> #13 0x73513542 in GDALDriver::Create (this=0xb9227790,
> pszFilename=0x73c33f2a "", nXSize=2, nYSize=2, nBands=0, eType=GDT_Byte,
> papszOptions=0x0) at gdaldriver.cpp:128
> #14 0x7351412f in GDALCreate (hDriver=0xb9227790, pszFilename=0x73c33f2a
> "", nXSize=2, nYSize=2, nBands=0, eBandType=GDT_Byte, papszOptions=0x0) at
> gdaldriver.cpp:254
> #15 0x73c05d04 in rt_raster_gdal_rasterize (wkb=0xb916a858 "\001\001",
> wkb_len=21, srs=0x0, num_bands=0, pixtype=0x0, init=0x0, value=0x0,
> nodata=0x0, hasnodata=0x0, width=0x0,
> height=0x0, scale_x=0xbfbde068, scale_y=0xbfbde088, ul_xw=0x0,
> ul_yw=0x0, grid_xw=0xbfbde060, grid_yw=0xbfbde078, skew_x=0xbfbde070,
> skew_y=0xbfbde080, options=0x0)
> at rt_api.c:11313
> #16 0x73bd37e8 in RASTER_setPixelValuesGeomval (fcinfo=0xb9295644) at
> rt_pg.c:3729
> #17 0xb73f3f90 in ?? ()
> #18 0x73c85dd7 in ?? () from /usr/lib/postgresql/9.3/lib/plpgsql.so
> #19 0x73c89be9 in ?? () from /usr/lib/postgresql/9.3/lib/plpgsql.so
> #20 0x73c8b708 in ?? () from /usr/lib/postgresql/9.3/lib/plpgsql.so
> #21 0x73c8c371 in plpgsql_exec_function () from
> #22 0x73c80334 in plpgsql_call_handler () from
> #23 0xb73f3f90 in ?? ()
> #24 0xb73f8919 in ExecProject ()
> #25 0xb73f8cec in ExecScan ()
> #26 0xb740c45f in ExecCteScan ()
> #27 0xb73f10b0 in ExecProcNode ()
> #28 0xb73edfbe in standard_ExecutorRun ()
> #29 0xb73ee07d in ExecutorRun ()
> #30 0xb74e8013 in ?? ()
> #31 0xb74e949e in PortalRun ()
> #32 0xb74e5242 in PostgresMain ()
> #33 0xb7298be8 in ?? ()
> #34 0xb7499058 in PostmasterMain ()
> #35 0xb7299bb9 in main ()
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140310/71106f01/attachment.html>
