[postgis-devel] Release PostGIS 2.1.2?
Devrim Gündüz
devrim at gunduz.org
Thu Mar 27 00:08:16 PDT 2014
Packager speaking: Can you please release 2.1.2 either on Thursday or Monday, and not release on Friday, to avoid upgrade nightmare during weekend?
Regards, Devrim
On March 27, 2014 8:50:37 AM EET, Sandro Santilli <strk at keybit.net> wrote:
>+1 for release, thanks Regina for testing
>PS: I think it's correct for ST_DumpPoints to never return POINT EMPTY
>--strk;
>On Thu, Mar 27, 2014 at 01:15:39AM -0400, Paragon Corporation wrote:
>> +1 Regina
>> I did a garden regression check between
>> 2.1.1, 2.0.4, and 2.1.2dev r12366 (on 9.2 windows 32-bit install)
>> There are fewer regressions between 2.0.4 and 2.1.2dev than there are
>> between 2.1.1 and 2.1.2dev
>> That is expected since 2.1.0 introduced a lot of geography
>regressions
>> (ST_Intersects, ST_DWithin) which got fixed in 2.1.2
>> The cases where I saw 2.0.4 and 2.1.2dev differences were with things
>like
>> intersects with geography M types where 2.0.4 was clearly wrong (if I
>forced
>> to remove M)
>> and things like Area, Length, intersection which were affected by
>SRID
>> changes. Also ST_Summary which outputs [S] (2.1.1 also has it) for
>has
>> spatial ref id I guess.
>> The results of outputs of ST_Length, ST_Length2D, ST_ExteriorRing,
>> ST_Perimeter (for curved types, polyhedral, and tin) (I think Length,
>and
>> ExteriorRing are bug fixes, not sure about perimeter)
>> The only other -- more interesting than anything is behavior of
>> ST_DumpPoints - though not sure I'd call this a bug
>> SELECT ST_AsText((ST_DumpPoints(ST_GeomFromText('POINT
>EMPTY',4326))).geom);
>> -- in 2.0.4 returns POINT EMPTY, in 2.1.1 and 2.1.2dev returns no
>records
>> Oddly for the other empty types no records are returned for any of
>them -
>> 2.0.4, 2.1.1, 2.1.2dev r12366 yields same non-existent answer
>> SELECT ST_ASText((ST_DumpPoints(foo1.the_geom)).geom),
>> ST_AsText(foo1.the_geom) As result
>> FROM ((
>> SELECT ST_GeomFromText('MULTIPOINT EMPTY',4326) As the_geom
>> UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON EMPTY',4326) As
>the_geom
>> UNION ALL SELECT ST_GeomFromText('LINESTRING EMPTY',4326) As
>the_geom
>> UNION ALL SELECT ST_GeomFromText('MULTILINESTRING EMPTY',4326) As
>> the_geom ) ) As foo1
>> Thanks,
>> Regina
>> _____
>> From: postgis-devel-bounces at lists.osgeo.org
>> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul
>Ramsey
>> Sent: Wednesday, March 26, 2014 8:45 AM
>> To: PostGIS Development Discussion
>> Subject: [postgis-devel] Release PostGIS 2.1.2?
>> Shall we? Ticket count is down, many important bugs fixed.
>> +1 Paul
>> Paul Ramsey
>> http://cleverelephant.ca
>> http://postgis.net
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140327/b865dad8/attachment.html>
