[postgis-devel] Implement New Geometry Index Method?
Jeremy Palmer
JPalmer at linz.govt.nz
Wed May 21 02:23:02 PDT 2014
> I agree it would be good to havea "gridding" function in PostGIS, but I don't really see it as being part of "indexing".
> Gridding produces better indexes but also augment the number of records so it takes some user design to decide how to layout the data.
Could the user design parameters not be part of the index creation storage parameters?
> One thing to keep in mind is that splitting on a regular grid would necessarely introduce new vertices which in turn
> would slighly move the original edges and possibly introduce collapses/invalidities.
Yes I did think that this might occur, especially considering I'm using decimal degree coordinates. So far with my process I've been lucky not to run into this :)
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
