[postgis-devel] Implement New Geometry Index Method?
Jeremy Palmer
JPalmer at linz.govt.nz
Wed May 21 04:26:40 PDT 2014
> Only if the idea is not to change the table structure.
> I mean, do you still want to retain large geometries in each record ?
Yes I'm sure my use case I would.
> Would you then have multiple index items all pointing to a single record ?
I guess so. Is that a problem?
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
