[postgis-devel] getPoint_internal and alignment
Sandro Santilli strk at keybit.net
Thu Sep 18 02:28:45 PDT 2014
Paul, while reading ptarray.c I stumbled across this comment:
   * Get a pointer to nth point of a POINTARRAY.
   * You cannot safely cast this to a real POINT, due to memory alignment
   * constraints. Use getPoint*_p for that.
  uint8_t *
  getPoint_internal(const POINTARRAY *pa, int n)
Is that still the new serialization format ?
Or can we safely cast the return to a POINT ?
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
