[postgis-devel] How to recreate comments?
Nicklas Avén nicklas.aven at jordogskog.no
Mon Sep 29 12:46:20 PDT 2014
Not distclean just clean.
I will try that. But last try was from new fresh checkout.
/Nicklas
Skickat från min Samsung Mobil.
<div>-------- Originalmeddelande --------</div><div>Från: Paragon Corporation <lr at pcorp.us> </div><div>Datum:2014-09-29  21:26  (GMT+01:00) </div><div>Till: 'PostGIS Development Discussion' <postgis-devel at lists.osgeo.org> </div><div>Rubrik: Re: [postgis-devel] How to recreate comments? </div><div>
</div>Well I deleted my postgis_comments.sql and it rebuilt so if there was a
problem with mine, it seeems different from yours.
Are you doing:
make distclean
make && make install
To build?
Regina
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: Monday, September 29, 2014 3:01 PM
To: 'PostGIS Development Discussion'
Subject: Re: [postgis-devel] How to recreate comments?
Nicklas,
> I guess something is going on (or not going on ) in my installation.
> It has worked before, or I wouldn't have had a working extension
> installation.
> make[3]: Entering directory `/opt/dev/postgis/test/doc'
> make[3]: Nothing to be done for `comments'.
> make[3]: Leaving directory `/opt/dev/postgis/test/doc'
Hmm I think you found a bug.  I just looked at mine and noticed my
postgis_comments.sql is old dated 7/23/2014 But my postgis-out.xml is
9/24/2014.
I'm pretty sure I've been doing make clean. Though have to verify.
I think last change that was made was not to build comments during make
install because people said install should Just install stuff not build
anything. So maybe that isn't working right
> Is it ok if I just commit it otherwise. That breaks the build since
> the upgrade script won't work without the right comments (I
> experienced:-) )
Yes go ahead. NO big deal if you break the build in trunk.
I promise not to shoot you :)
Regina
postgis-devel mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140929/9e8f15d2/attachment.html>
