[postgis-devel] How to recreate comments?
Paragon Corporation lr at pcorp.us
Tue Sep 30 06:35:33 PDT 2014
I don't think it requires imagemagick.  I don't have imagemagick installed
on my desktop and it builds fine.
Thanks,
Regina
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Tuesday, September 30, 2014 2:56 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] How to recreate comments?
On Mon, Sep 29, 2014 at 08:31:57PM +0200, Nicklas Avén wrote:
> I guess something is going on (or not going on ) in my installation.
> It has worked before, or I wouldn't have had a working extension
> installation.
> When I run configure this is the last part of the status:
>  -------- Documentation Generation --------
>   xsltproc:             /usr/bin/xsltproc
>   xsl style sheets:     /usr/share/xml/docbook/stylesheet/nwalsh
>   dblatex:
>   convert:
>   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> make[3]: Entering directory `/opt/dev/postgis/test/doc'
> make[3]: Nothing to be done for `comments'.
> make[3]: Leaving directory `/opt/dev/postgis/test/doc'
> cp ../../doc/postgis_comments.sql sql_bits/postgis_comments.sql
> cp: cannot stat ‘../../doc/postgis_comments.sql’: No such file or
> directory
> Any ideas why it thinks there is nothing to do in doc?
See the CAN_BUILD_COMMENTS variable in doc/Makefile The configure.ac sets
that variable. I see it sets it to OFF if you don't have imagemagick, for
example, which is wrong.
We'd need more variables to determine if we can build comments or manual (of
different formats). Surely comments do not need imagemagick (convert).
A ticket would be nice.
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
