[postgis-devel] Help? 'No package postgis2_93 available'
Quais Afzali
jesuskwice at gmail.com
Wed Aug 5 19:11:11 PDT 2015
Thanks so much Devrim! Not sure how this install slipped on this
installment, but that seems to have done the trick.
Thanks again!
Quais.
On Wed, Aug 5, 2015 at 12:46 AM, Devrim GÜNDÜZ <devrim at gunduz.org> wrote:
> Hi,
> You need to install repo file first:
> http://yum.postgresql.org/repopackages.php#pg93
> Then, you can install this package.
> Regards, Devrim
> On Tue, 2015-08-04 at 18:57 -0700, Quais Afzali wrote:
> > Hello,
> > I tried googling around and digging around the docs on site, to no
> > avail.
> > Really hoping someone on this alias can help, as I've hit a pretty
> > bad wall
> > here..
> > Basically, I'm simply trying to install postgis on my Centos 6x64
> > box,
> > using:
> > *'yum install postgis2_93'*
> > as detailed in the docs (I'm already running Postgres 9.3 on it).
> > This,
> > however, gives me the following:
> > [quais at server ~]$ *sudo yum install postgis2_93*
> > Loaded plugins: fastestmirror
> > Setting up Install Process
> > Loading mirror speeds from cached hostfile
> > * base: ftpmirror.your.org
> > * extras: mirrors.cmich.edu
> > * updates: cosmos.cites.illinois.edu
> > *No package postgis2_93 available.*
> > Error: Nothing to do
> > Any insight as to what I could be doing wrong?
> > Any help much appreciated!
> > Quais.
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> Devrim GÜNDÜZ
> Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
> Twitter: @DevrimGunduz , @DevrimGunduzTR
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150805/055aad35/attachment.html>
