[postgis-devel] how to add my JTS in postgis?
xschen
xschen at clustertech.com
Sat Aug 8 04:59:16 PDT 2015
I download the JTS source code , and add an algrithem in it.
now , i want to remove the pervious JTS of postgis and add my JTS into
it to test.
how to?
BTW, the algrithem is to replace this package:
package com.vividsolutions.jts.geomgraph.index;
public class SimpleEdgeSetIntersector extends EdgeSetIntersector
private void computeIntersects(Edge e0, Edge e1, SegmentIntersector
si)
com.vividsolutions.jts.geom.Coordinate pts0[] =
e0.getCoordinates();
com.vividsolutions.jts.geom.Coordinate pts1[] =
e1.getCoordinates();
for(int i0 = 0; i0 < pts0.length - 1; i0++)
for(int i1 = 0; i1 < pts1.length - 1; i1++)
si.addIntersections(e0, i0, e1, i1);
if an n points line intersects an n points line ,the complexity will be
O(n*n).
this algrithem wiil show very low performance, if n>10000
my algrithem is to cut each line into sevel small pieces, group them
into 4 branch trees boxes and join, then calculate the intersects of
small pieces in the same boxes.
so that the complexity will be O(nlog(n)).
