[postgis-devel] Not receiving SRID conflict error
David Haynes II dahaynes at umn.edu
Fri Jan 16 08:52:06 PST 2015
Sorry, I am not understanding what is happening can you explain?
On Fri, Jan 16, 2015 at 10:18 AM, Bborie Park <dustymugs at gmail.com> wrote:
> Yes, the following explains it.
> SELECT 'SRID=4269;POINT(-1 -1)'::geometry &&
> ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 0, 1, -1, 0, 0, 4326), 1, '16BUI',
> 1, 0)
> and
> SELECT ST_Intersects('SRID=4269;POINT(-1 -1)'::geometry,
> 1, 0))
> On Fri, Jan 16, 2015 at 8:14 AM, Bborie Park <dustymugs at gmail.com> wrote:
>> Do you have a spatial index on IGBP_2012?
>> The only thing I can think of is that dasymetric.us_dem_prj has a
>> spatial index and since ST_Intersects() uses the spatial index first, there
>> is no rows to consider in ST_Intersects and ST_Clip.
>> -bborie
>> On Fri, Jan 16, 2015 at 7:56 AM, David Haynes II <dahaynes at umn.edu>
>> wrote:
>>> Hello,
>>> I have a question about an error I am not receiving when I believe I
>>> should.
>>> Below are three datasets that with their SRID
>>> igbp_2012 (6842), us_dem_prj (3410), and us_states (4326).
>>> When I run a query determining the SRID for these datasets in PostgreSQL
>>> they confirm their SRIDs
>>> select st_srid(r.rast), st_srid(p.geom) from dasymetric.us_dem_prj r,
>>> dasymetric.us_states p limit 5
>>> When I run the next query, I do not receive an error, but no records are
>>> returned. The raster is in 3410 and the states geom column is in 4326
>>> SELECT state_label, ST_Clip(r.rast,p.geom) as rast FROM
>>> dasymetric.us_states p inner join dasymetric.us_dem_prj r on
>>> ST_Intersects(p.geom, r.rast) WHERE p.state_label = 'Minnesota'
>>> However, If I adjust the raster dataset to IGBP_2012, the error
>>> ERROR: Raster and geometry do not have the same SRID, shows up.
>>> Why am I not receiving a conflict projection error for a raster in 3410
>>> and a geometry in 4326? Any idea why that is occurring?
>>> David Haynes, Ph.D.
>>> Research Associate Terra Populus
>>> Minnesota Population Center
>>> www.terrapop.org
>>> postgis-devel mailing list
>>> postgis-devel at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
David Haynes, Ph.D.
www.terrapop.org
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150116/5806c708/attachment.html>
