[postgis-devel] Not receiving SRID conflict error
Bborie Park
dustymugs at gmail.com
Fri Jan 16 08:58:52 PST 2015
The first SELECT only uses the spatial index check (&&) and returns false.
The second SELECT uses ST_Intersects() (which makes use of the spatial
index first) and also returns false.
The code for ST_Intersects(geom, raster) is...
CREATE OR REPLACE FUNCTION st_intersects(geom geometry, rast raster, nband
integer DEFAULT NULL)
RETURNS boolean AS
$$ SELECT $1 && $2::geometry AND _st_intersects($1, $2, $3); $$
LANGUAGE 'sql' IMMUTABLE
COST 1000;
Because the input geometry and raster fail the spatial index test (&&), the
"internal" _st_intersects() function never receives any data where the SRID
check is done.
On Fri, Jan 16, 2015 at 8:52 AM, David Haynes II <dahaynes at umn.edu> wrote:
> Sorry, I am not understanding what is happening can you explain?
> On Fri, Jan 16, 2015 at 10:18 AM, Bborie Park <dustymugs at gmail.com> wrote:
>> Yes, the following explains it.
>> SELECT 'SRID=4269;POINT(-1 -1)'::geometry &&
>> ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 0, 1, -1, 0, 0, 4326), 1, '16BUI',
>> 1, 0)
>> and
>> SELECT ST_Intersects('SRID=4269;POINT(-1 -1)'::geometry,
>> 1, 0))
>> On Fri, Jan 16, 2015 at 8:14 AM, Bborie Park <dustymugs at gmail.com> wrote:
>>> Do you have a spatial index on IGBP_2012?
>>> The only thing I can think of is that dasymetric.us_dem_prj has a
>>> spatial index and since ST_Intersects() uses the spatial index first, there
>>> is no rows to consider in ST_Intersects and ST_Clip.
>>> -bborie
>>> On Fri, Jan 16, 2015 at 7:56 AM, David Haynes II <dahaynes at umn.edu>
>>> wrote:
>>>> Hello,
>>>> I have a question about an error I am not receiving when I believe I
>>>> should.
>>>> Below are three datasets that with their SRID
>>>> igbp_2012 (6842), us_dem_prj (3410), and us_states (4326).
>>>> When I run a query determining the SRID for these datasets in
>>>> PostgreSQL they confirm their SRIDs
>>>> select st_srid(r.rast), st_srid(p.geom) from dasymetric.us_dem_prj r,
>>>> dasymetric.us_states p limit 5
>>>> When I run the next query, I do not receive an error, but no records
>>>> are returned. The raster is in 3410 and the states geom column is in 4326
>>>> SELECT state_label, ST_Clip(r.rast,p.geom) as rast FROM
>>>> dasymetric.us_states p inner join dasymetric.us_dem_prj r on
>>>> ST_Intersects(p.geom, r.rast) WHERE p.state_label = 'Minnesota'
>>>> However, If I adjust the raster dataset to IGBP_2012, the error
>>>> ERROR: Raster and geometry do not have the same SRID, shows up.
>>>> Why am I not receiving a conflict projection error for a raster in 3410
>>>> and a geometry in 4326? Any idea why that is occurring?
>>>> David Haynes, Ph.D.
>>>> Research Associate Terra Populus
>>>> Minnesota Population Center
>>>> www.terrapop.org
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> David Haynes, Ph.D.
> www.terrapop.org
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150116/6d1a668c/attachment.html>
