[postgis-devel] parallel build bug (in 2.1.8)
Sandro Santilli
strk at keybit.net
Tue Jul 7 13:40:04 PDT 2015
On Tue, Jul 07, 2015 at 02:25:27PM -0400, Greg Troxel wrote:
> In the pkgsrc build, make is invoked as "all docs" to build everything.
> Without -j, it works fine. With -j, deep down in docs, there is a rule
> to build liblwgeom.a, which collides with the build from the all target.
> The following patches a dependency from docs to all, and also remove the
> reach-back rule. They appear to fix doing parallel builds. If it
> isn't appropriate to force all from docs, then arguably liblwgeom should
> be split out and both all and docs depend on that.
+1 for splitting out liblwgeom. It's its natural path anyway.
> Does building with -j8 work for other people?
It never worked for me. I was impressed by automake when I saw
how many things it can get right which I couldn't :)
PS: no need to Cc the @refractions mailing list as it should just
be an alias to the @osgeo one
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
