[postgis-devel] PSC vote Request: Make Geos 3.5 the default in PostGIS 2.2
Paragon Corporation
lr at pcorp.us
Mon May 25 05:40:31 PDT 2015
Yap. Then I can document it too and have my garden tester test it :)
Thanks,
Regina
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at cleverelephant.ca]
Sent: Monday, May 25, 2015 8:20 AM
To: PostGIS Development Discussion; Paragon Corporation
Subject: Re: [postgis-devel] PSC vote Request: Make Geos 3.5 the default in PostGIS 2.2
Would all this be moot if I just stubbed in a box-only implementation of <-> for geography to be used in earlier versions?
http://postgis.net
http://cleverelephant.ca
On May 25, 2015 at 4:46:12 AM, Paragon Corporation (lr at pcorp.us) wrote:
> Well I was only thinking of the KNN geography because that changes the
> operator class from 9.4 to 9.5 and also introduces new operators.
> I thought the <-> was under the hood (used the same function in both
> cases) so when they upgrade to 9.5 that would be a non-issue.
> By binary -- I meant to say in-place upgrade where the sql definitions
> of the functions don't get upgraded by a new CREATE EXTENSION call
> like backup and restore does.
> Binaries change of course since a 9.4 binary would never work on a 9.5
> install anyway, but yah having postgis_full_version expose the version
> it was built from would solve that problem. But that would have to be
> a plpgsql embedded solution since the binaries would be 9.5 Thogh the
> function definitions came from a 9.4 upgrade.
> From: postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro
> Santilli
> Sent: Monday, May 25, 2015 3:15 AM
> On Sun, May 24, 2015 at 10:24:11AM -0400, Paragon Corporation wrote:
> > strk, Paul - any thoughts on how to deal with that one? When you run
> > pg_upgrade, since it's doing a binary upgrade, I don't think CREATE
> > EXTENSION is run so the functions just get pulled over.
> We're talking about <-> semantic changing based on PostgreSQL version,
> right ? That's not the only case of PostgreSQL version dependent
> behavior, another one is presence or absence of the whole index-assisted KNN.
> The only idea I have about this is to expose the version of PostgreSQL
> PostGIS was built against so that postgis_full_version() can complain
> about it and recommend a re-build/re-install. Then we need to also
> allow for upgrades between same versions as we already do with the "next" trick.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
