[postgis-devel] PSC vote Request: Make Geos 3.5 the default in PostGIS 2.2
Sandro Santilli
strk at keybit.net
Mon May 25 07:00:34 PDT 2015
On Mon, May 25, 2015 at 05:19:56AM -0700, Paul Ramsey wrote:
> Would all this be moot if I just stubbed in a box-only implementation of <-> for geography to be used in earlier versions?
If no match comes out from:
grep '#if.*PGSQL' postgis/postgis.sql.in
Then the problem is only with the binary (so, not a problem).
Otherwise, upgrade beween PostgreSQL versions would still need
an extension upgrade (even if to the same PostGIS version).
--strk;
