[postgis-devel] Public Raster C API
Nathaniel Clay
clay.nathaniel at gmail.com
Thu May 28 00:04:19 PDT 2015
Bborie,
Just to be clear we need to move from static linking to dynamic linking and
separate out "librtcore.so" from "rtpostgis.so". This can be done with
libtool, honestly this would be my first attempt at using Autotools can I
get a little hand holding here.
Humbly,
Nathaniel Hunter Clay
On Wed, May 27, 2015 at 8:10 PM, Bborie Park <dustymugs at gmail.com> wrote:
> Hm... Sounds like the Makefile needs changing to install librtcore.so.
> On Wed, May 27, 2015 at 4:22 PM, Nathaniel Clay <clay.nathaniel at gmail.com>
> wrote:
>> Bborie,
>> I think it all gets rolled up into rtpostgis.so. As far as I can tell
>> there is no librtcore.so.
>> Thanks,
>> On Wed, May 27, 2015 at 7:13 PM, Bborie Park <dustymugs at gmail.com> wrote:
>>> Nah. The library was meant to be consumed by whomever wants to consume
>>> it. If the header is not copied, that'd be an oversight and a ticket should
>>> be filed... Having said that I need to see where librtcore.so gets
>>> installed...
>>> On Wed, May 27, 2015 at 2:41 PM, Nathaniel Clay <
>>> clay.nathaniel at gmail.com> wrote:
>>>> Bborie,
>>>> The librtcore header is not copied, to /usr/include so I am assuming
>>>> that the library functions included in the library were meant to be
>>>> private. This is for a external project. Is this an over-site? Or am I
>>>> missing something fundamental.
>>>> Thanks as Always,
>>>> On Wed, May 27, 2015 at 5:35 PM, Bborie Park <dustymugs at gmail.com>
>>>> wrote:
>>>>> Actually, yes. raster2pgsql directly consumes librtcore...
>>>>> On Wed, May 27, 2015 at 2:33 PM, Bborie Park <dustymugs at gmail.com>
>>>>> wrote:
>>>>>> Do you mean directly accessing librtcore? I believe you can go
>>>>>> directly at that library if so inclined.
>>>>>> -bborie
>>>>>> On Wed, May 27, 2015 at 2:31 PM, Nathaiel Clay <
>>>>>>> Hi All,
>>>>>>> Could we expose some of the raster C functions to read and write to
>>>>>>> raster’s, and low level pixel to geo-point and geo-point to pixel and etc.
>>>>>>> Just want your input, I am more than willing to do the work myself.
>>>>>>> Thanks,
>>>>>>> _______________________________________________
>>>>>>> postgis-devel mailing list
>>>>>>> postgis-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150528/56a4f9c5/attachment.html>
