[postgis-devel] Public Raster C API
Bborie Park dustymugs at gmail.com
Thu May 28 07:31:59 PDT 2015
Yes as long as we can get it in before the end of June.
On Wed, May 27, 2015 at 5:59 PM, Nathaniel Clay <clay.nathaniel at gmail.com>
wrote:
> Bborie,
> I'll ticket the problem and as I said earlier, I will fix it myself. You
> comfortable with getting the change into 2.2?
> Thanks,
> Nathaniel Hunter Clay
> On Wed, May 27, 2015 at 8:10 PM, Bborie Park <dustymugs at gmail.com> wrote:
>> Hm... Sounds like the Makefile needs changing to install librtcore.so.
>> On Wed, May 27, 2015 at 4:22 PM, Nathaniel Clay <clay.nathaniel at gmail.com
>> > wrote:
>>> Bborie,
>>> I think it all gets rolled up into rtpostgis.so. As far as I can tell
>>> there is no librtcore.so.
>>> Thanks,
>>> On Wed, May 27, 2015 at 7:13 PM, Bborie Park <dustymugs at gmail.com>
>>> wrote:
>>>> Nah. The library was meant to be consumed by whomever wants to consume
>>>> it. If the header is not copied, that'd be an oversight and a ticket should
>>>> be filed... Having said that I need to see where librtcore.so gets
>>>> installed...
>>>> On Wed, May 27, 2015 at 2:41 PM, Nathaniel Clay <
>>>> clay.nathaniel at gmail.com> wrote:
>>>>> Bborie,
>>>>> The librtcore header is not copied, to /usr/include so I am assuming
>>>>> that the library functions included in the library were meant to be
>>>>> private. This is for a external project. Is this an over-site? Or am I
>>>>> missing something fundamental.
>>>>> Thanks as Always,
>>>>> On Wed, May 27, 2015 at 5:35 PM, Bborie Park <dustymugs at gmail.com>
>>>>> wrote:
>>>>>> Actually, yes. raster2pgsql directly consumes librtcore...
>>>>>> On Wed, May 27, 2015 at 2:33 PM, Bborie Park <dustymugs at gmail.com>
>>>>>> wrote:
>>>>>>> Do you mean directly accessing librtcore? I believe you can go
>>>>>>> directly at that library if so inclined.
>>>>>>> -bborie
>>>>>>> On Wed, May 27, 2015 at 2:31 PM, Nathaiel Clay <
>>>>>>>> Hi All,
>>>>>>>> Could we expose some of the raster C functions to read and write to
>>>>>>>> raster’s, and low level pixel to geo-point and geo-point to pixel and etc.
>>>>>>>> Just want your input, I am more than willing to do the work myself.
>>>>>>>> Thanks,
>>>>>>>> _______________________________________________
>>>>>>>> postgis-devel mailing list
>>>>>>>> postgis-devel at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150528/2c3bebe2/attachment.html>
