[postgis-devel] Public Raster C API
Sandro Santilli strk at keybit.net
Thu May 28 03:32:47 PDT 2015
On Wed, May 27, 2015 at 05:10:18PM -0700, Bborie Park wrote:
> Hm... Sounds like the Makefile needs changing to install librtcore.so.
It needs to give the library a version, build the shared one and
install it.
Nathaniel: you can look at how this is done for liblwgeom.
--strk;
> On Wed, May 27, 2015 at 4:22 PM, Nathaniel Clay <clay.nathaniel at gmail.com>
> wrote:
> > Bborie,
> > I think it all gets rolled up into rtpostgis.so. As far as I can tell
> > there is no librtcore.so.
> > Thanks,
> > Nathaniel Hunter Clay
> > On Wed, May 27, 2015 at 7:13 PM, Bborie Park <dustymugs at gmail.com> wrote:
> >> Nah. The library was meant to be consumed by whomever wants to consume
> >> it. If the header is not copied, that'd be an oversight and a ticket should
> >> be filed... Having said that I need to see where librtcore.so gets
> >> installed...
> >> On Wed, May 27, 2015 at 2:41 PM, Nathaniel Clay <clay.nathaniel at gmail.com
> >> > wrote:
> >>> Bborie,
> >>> The librtcore header is not copied, to /usr/include so I am assuming
> >>> that the library functions included in the library were meant to be
> >>> private. This is for a external project. Is this an over-site? Or am I
> >>> missing something fundamental.
> >>> Thanks as Always,
> >>> On Wed, May 27, 2015 at 5:35 PM, Bborie Park <dustymugs at gmail.com>
> >>> wrote:
> >>>> Actually, yes. raster2pgsql directly consumes librtcore...
> >>>> On Wed, May 27, 2015 at 2:33 PM, Bborie Park <dustymugs at gmail.com>
> >>>> wrote:
> >>>>> Do you mean directly accessing librtcore? I believe you can go
> >>>>> directly at that library if so inclined.
> >>>>> -bborie
> >>>>> On Wed, May 27, 2015 at 2:31 PM, Nathaiel Clay <
> >>>>> clay.nathaniel at gmail.com> wrote:
> >>>>>> Hi All,
> >>>>>> Could we expose some of the raster C functions to read and write to
> >>>>>> raster’s, and low level pixel to geo-point and geo-point to pixel and etc.
> >>>>>> Just want your input, I am more than willing to do the work myself.
> >>>>>> Thanks,
> >>>>>> _______________________________________________
> >>>>>> postgis-devel mailing list
> >>>>>> postgis-devel at lists.osgeo.org
> >>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
