[postgis-devel] PostGIS 2.2 for PostgreSQL 9.5 Windows 64 bit
Paragon Corporation
lr at pcorp.us
Mon Oct 12 13:48:35 PDT 2015
Pieter,
Thanks for reporting. Hadn't had a chance to check the 9.5 yet after I built because I had to confirm a change they made in the VC++ builds that was different from prior editions so I had to make a special build for this separate from the others.
In doing so I neglected to enable SFCGAL and address standardizer building. Rebuilding now. Can you redownload in about 30 minutes. Should then have SFCGAL and address_standardizer support.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Pieter du Plooy
Sent: Monday, October 12, 2015 12:01 PM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] PostGIS 2.2 for PostgreSQL 9.5 Windows 64 bit
Hi guys
I have just installed PG 9.5, and downloaded the PostGIS 2.2 for 9.5 (Windows 64).
I cannot create the sfcgal and address standardizer extensions.
I get the following errors:
ERROR: could not stat file "C:/Program Files/PostgreSQL/9.5/share/extension/postgis_sfcgal--2.2.0.sql": No such file or directory
and
ERROR: could not stat file "C:/Program Files/PostgreSQL/9.5/share/extension/address_standardizer--2.2.0.sql": No such file or directory
It is only the appropriate comments.sql for these two that exist.
Could you please check?
Regards
Pieter du Plooy
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20151012/6dd9cb88/attachment.html>
