[postgis-devel] PostGIS 2.2 for PostgreSQL 9.5 Windows 64 bit
    Pieter du Plooy
    pjduplooy at zpanelcp.com
    Mon Oct 12 09:01:17 PDT 2015
Hi guys
I have just installed PG 9.5, and downloaded the PostGIS 2.2 for 9.5
(Windows 64).
I cannot create the sfcgal and address standardizer extensions.
I get the following errors:
ERROR:  could not stat file "C:/Program
Files/PostgreSQL/9.5/share/extension/postgis_sfcgal--2.2.0.sql": No such
file or directory
and
Files/PostgreSQL/9.5/share/extension/address_standardizer--2.2.0.sql": No
such file or directory
It is only the appropriate comments.sql for these two that exist.
Could you please check?
Regards
Pieter du Plooy
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20151012/cfea8d4d/attachment.html>
