[postgis-devel] Creation of standard set of geometries for testing? Interested?
Greg Troxel
gdt at ir.bbn.com
Wed Oct 21 06:30:42 PDT 2015
Nyall Dawson <nyall.dawson at gmail.com> writes:
>> 2. Hadn't really thought of our tests licensing. Technically they
>> are all GPL like the rest of our code base, but it seems silly to me
>> not to have those public domain.
>> Though I'm not sure what kind of headache we'd have changing the license on those.
> Yeah... I'm not sure either. I'm not even sure if there'd be issues
> copying arbitrary geometries such as these and changing the license.
> But then, I'm not a copyright lawyer ;) Maybe we could make a derived
> set by slightly altering the existing geometries (such as adding 1 to
> all the coordinates)... would that help?
No, that will not help.
It could be that they aren't sufficiently creative to merit copyright,
in which case they already are public domain. I doubt this, though;
generating test sets requires thought.
Or, if they are copyrighted, and you want to use them other than under
the GPL, you need permission from the authors/copyright holders.
If there is a test data set, though - what's the problem with GPL? It
can be installed as a package, with inputs and outputs, and then
programs of whatever license (even gasp a proprietary licensse) can be
run on the inputs and the outputs compared. Or is it that you already
have a big PD set and want to enhance it?
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20151021/8636fda1/attachment.sig>
