[postgis-devel] Using DirectFunctionCall with more than 9 arguments (LWGEOM_affine)
Philip Grimes ptgrimes235 at gmail.com
Fri Apr 22 14:56:36 PDT 2016
Hello all,
I am pretty new to postgis development, and am trying to write some
geometric manipulation functions as a c extension for a small performance
boost. The problem is that the function I want to call from the C code
directly is st_rotate (which is defined by st_affine, or LWGEOM_affine).
This function takes in 13 arguments, so I created my own
DirectFunctionCall13Coll that was implemented identically to 1-9, however
when I run the function with a 0 degree rotation, the return value is a
polygon, but the points are of the order of ~e-324, which is much smaller
than I was expecting. I wasn't quite sure what I was doing wrong.
Here is the the input and output of the function.
NOTICE:  input of LWGEOM_affine
DETAIL:  hull WKT: POLYGON((1 1,1 7,4 8,8 5,1 1))
NOTICE:  Output of func pointer
DETAIL:  rot WKT: POLYGON((4.94065645841247e-324
4.94065645841247e-324,4.94065645841247e-324
3.45845952088873e-323,1.97626258336499e-323
3.95252516672997e-323,3.95252516672997e-323
2.47032822920623e-323,4.94065645841247e-324 4.94065645841247e-324))
And it is called with these arguments, with the macro for the
DirectFunctionCall13Coll using the default collation valid.
DirectFunctionCall13(LWGEOM_affine, hull, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0,
0);
Does anyone have any ideas why this is happening. We are using postgresql
9.2 and postgis 2.0.6.
Thanks,
Phil
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160422/b2de8f73/attachment.html>
