[postgis-devel] ST_Colormap
David Haynes II
dahaynes at umn.edu
Wed Apr 27 06:30:55 PDT 2016
Thanks for that information Regina. Your right, ST_Colormap does retain the
projection information. That's interesting as I have been able to retain
the spatial information in a jpeg using gdal_translate without creating the
jpegw file.
Thanks
On Tue, Apr 26, 2016 at 12:48 AM, Regina Obe <lr at pcorp.us> wrote:
> David,
> I could be mistaken, but I always thought that for jpegs the spatial info
> is stored in a .jpegw file and since ST_ASJPEG only outputs the jpg part it
> wouldn't keep the spatial ref info.
> Are you saying you loose it at the ST_ColorMap part or the ST_AsJPEG. I
> would expect it maintained in ST_ColorMap and lost at ST_AsJPEG call.
> Thanks,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *David Haynes II
> *Sent:* Friday, April 22, 2016 12:51 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> *Subject:* [postgis-devel] ST_Colormap
> Hello
> Working on an application for clipping rasters (
> data.terrapop.org/terraclip) and running into an issue with the
> ST_Colormap function. It seems that whenever we run the ST_Colormap
> function we lose the spatial reference information for the image.This is
> the sample of the query that we are running. The query is successful, but
> the resulting images can be built into a vrt with gdal. I'm using
> PostgreSQL 9.3.7 and POSTGIS 2.1.7.
> WITH projection as
> SELECT ST_SRID(rast) as srid
> FROM gis_rasters.apricothar
> Limit 1
> ),polygon as
> SELECT sgl.id as sample_geog_level_id, gi.id as geog_instance_id,
> gi.label as geog_instance_label,
> gi.code as geog_instance_code, ST_Transform(bound.geog::geometry,
> prj.srid) as geom
> FROM projection prj, sample_geog_levels sgl
> inner join geog_instances gi on sgl.id = gi.sample_geog_level_id
> inner join boundaries bound on bound.geog_instance_id = gi.id
> WHERE sgl.id = 226
> ),raster_clip as
> SELECT ST_Clip(r.rast, 1, p.geom, TRUE) AS rast
> FROM polygon p inner join gis_rasters.apricothar r on
> ST_Intersects(r.rast,p.geom)
> select ST_AsJPEG(ST_Colormap(rast, 1, 'greyscale')) as img
> from raster_clip, projection prj
> David Haynes, Ph.D.
> Research Associate Terra Populus
> Minnesota Population Center
> 612-626-3933
> www.terrapop.org
> postgis-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
David Haynes, Ph.D.
612-626-3933
www.terrapop.org
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160427/a3f677eb/attachment.html>
