[postgis-devel] Import Foreign Schema Fails with “schema postgis does not exist”
Andrew Joseph
ap.joseph at live.com
Sun Aug 7 10:12:44 PDT 2016
I am connecting to a Postgres 9.4 foreign server instance where Postgis 2.1
was installed using CREATE EXTENSION postgis WITH SCHEMA postgis from a
Postgres 9.6 Beta where Postgis 2.3dev was installed with CREATE EXTENSION
postgis in the public schema (see gis.stackexchange question:
http://gis.stackexchange.com/questions/206098/import-foreign-schema-fails-with-schema-postgis-does-not-exist).
When running:
IMPORT FOREIGN SCHEMA data_schema FROM SERVER f_server INTO data_schema;
I receive the following error:
[2016-08-07 11:23:36] [3F000] ERROR: schema "postgis" does not exist
Where: importing foreign table "data_table"
[2016-08-07 11:23:36] [25P02]
WHERE data_table is defined as:
CREATE TABLE data_schema.data_table(
id bigserial PRIMARY KEY,
geom geometry(MultiPolygon,4326)
CREATE INDEX ON data_schema.data_table USING GIST (geom);
I am aware that some postgis functions have schema qualification issues, as
demonstrated by this postgis ticket; however that doesn't seem to be the
issue I am encountering since I merely have a geometry column and a GIST
index.
Tried importing the postgis schema from the foreign server as well, but that
errors out with:
IMPORT FOREIGN SCHEMA postgis FROM SERVER f_server INTO postgis
[2016-08-07 11:43:08] [42704] ERROR: type "postgis.geometry" does not exist
Where: importing foreign table "raster_columns"
Foreign Server Definition:
CREATE SERVER f_server
FOREIGN DATA WRAPPER postgres_fdw
OPTIONS (host 'localhost', port '5433', dbname 'f_db');
CREATE USER MAPPING FOR postgres
SERVER f_server
OPTIONS (user 'postgres', password 'password');
View this message in context: http://postgis.17.x6.nabble.com/Import-Foreign-Schema-Fails-with-schema-postgis-does-not-exist-tp5010326.html
Sent from the PostGIS - Dev mailing list archive at Nabble.com.
