[postgis-devel] BOX3D strange behaviour
Even Rouault
even.rouault at spatialys.com
Thu Feb 18 00:53:21 PST 2016
Le jeudi 18 février 2016 09:37:41, Sandro Santilli a écrit :
> On Wed, Feb 17, 2016 at 11:33:12AM -0800, Paul Ramsey wrote:
> > > On Feb 17, 2016, at 10:46 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> > > SELECT 'BOX3D( 0 0 0, 10 10 10)'::box3D::geometry &&&
> > > ST_Makepoint(5,5,-1)
> > select st_astext('BOX3D( 0 0 0, 10 10 10)'::box3D::geometry);
> Horrible. box3d::geometry drops the Z ?
> Was it always like that ?
Seems so:
=> select postgis_version(), st_astext('BOX3D( 0 0 0, 10 10 10)'::box3D::geometry);
postgis_version | st_astext
1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 | POLYGON((0 0,0 10,10 10,10 0,0 0))
(1 ligne)
2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 | POLYGON((0 0,0 10,10 10,10 0,0 0))
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
http://www.spatialys.com
