[postgis-devel] BOX3D strange behaviour
Rémi Cura remi.cura at gmail.com
Thu Feb 18 01:03:54 PST 2016
So what is the point to have a Box3D,
 as any use of it requires it to be casted to geometry,
which turns it into a box2D?
(Maybe I missed a way to use this 3D box with a 3D index so it uses Z? )
Is there any way to perform &&& in all 3 dimensions?
My problem is "give points whose X, Y, Z are inside the range R1,R2,R3",
and I'd prefer have one 3D geom gist index rather than 3 btree index on
coordinates.
I was thinking the 3DBox was smart, untill I spent quite some time tracking
subsequent errors to postgis.
Cheers,
Rémi-C
2016-02-18 9:53 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> Le jeudi 18 février 2016 09:37:41, Sandro Santilli a écrit :
> > On Wed, Feb 17, 2016 at 11:33:12AM -0800, Paul Ramsey wrote:
> > > > On Feb 17, 2016, at 10:46 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> > > > SELECT 'BOX3D( 0 0 0, 10 10 10)'::box3D::geometry &&&
> > > > ST_Makepoint(5,5,-1)
> > > select st_astext('BOX3D( 0 0 0, 10 10 10)'::box3D::geometry);
> > Horrible. box3d::geometry drops the Z ?
> > Was it always like that ?
> Seems so:
> => select postgis_version(), st_astext('BOX3D( 0 0 0, 10 10
>             postgis_version            |             st_astext
>  1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 | POLYGON((0 0,0 10,10 10,10 0,0 0))
> (1 ligne)
>  2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 | POLYGON((0 0,0 10,10 10,10 0,0 0))
> > --strk;
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/postgis-devel
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160218/004e7608/attachment.html>
