[postgis-devel] [postgis-tickets] r14554 - update version info, add note about upgradeable_versions.mk
Greg Troxel
gdt at ir.bbn.com
Wed Jan 6 06:04:57 PST 2016
Sandro Santilli <strk at keybit.net> writes:
> On Wed, Jan 06, 2016 at 08:30:04AM -0500, Greg Troxel wrote:
>> It could be reasonable to expect that anyone who runs an rc for real (vs
>> testing it) should be expected to upgrade to the corresponding release
>> first.
> Right, but there's no way to upgrade from an rc to a final
> unless we leave those names in the PostgreSQL extension upgrade
> scripts.
I meant that the version in 2.2.0 would have bits to upgrade from
2.2.0rc1, but that 2.2.1 would not.
> One thing that might make packaging easier would be avoiding
> to make _copies_ of those files but rather rely on symlinks
> or have the package post-install script make copies on systems
> that do not support symlinks. If you look at those zillion files
> many are just identical:
> # ls `pg_config --sharedir`/extension/postgis* | wc -l
> 954
> # md5sum `pg_config --sharedir`/extension/postgis* |
> awk '{print $1}' |
> sort -u | wc -l
> 156
Both symlinks and having the post-install script make copies are not
easier. What I do now is edit a control file in the packaging system
that lists the expected files. Symlinks count as files :-). So it
would have to be on-the-fly, or it won't help. I suspect it's best to
just put up with it, as on-the-fly generation seems unnecessarily
complex, harder to test, etc.
Some people think the manual manifest is a bug, but it is actually quite
useful. When I update pkgsrc from 2.1.8 to 2.2.0 I discovered that
there were several unintended/wrong changes to where some of the
topology files were installed. And then I noticed the presence of a
2.2.0.rc1 ugrade script (and lack of one from 2.2.0) when testing my
hand-rolled not-really-right rc distfile.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160106/8c3e2be8/attachment.sig>
