[postgis-devel] shp2pgsql
    Stefan Keller
    sfkeller at gmail.com
    Sun Jan 24 16:38:59 PST 2016
David, PostGIS developers
David: Is there any update on parallelizing shp2pgsql?
Devs (and David): Are there any plans to complement shp2pgsql with
something like GeoPackage-to-PostGIS (gpkg2pgsql) ?
I sometimes refer to vector GeoPackage as the "Shapefile of the
future". Rémi's pointer to OGR is also valuable. But I'd expect that a
standalone tool like gpkg2pgsql could eventually be easier to be
realized and tuned.
:Stefan
2015-02-18 17:37 GMT+01:00 Brent Wood <pcreso at pcreso.com>:
> You might look at the capabilities of systems like Netezza & Teradata. They
> have also adapted various tools around Postgres/Postgis to support
> parallelisation.
> This comment on Netezza might be of interest:
> http://geothought.blogspot.co.nz/2008/09/netezza-spatial.html
> Cheers
> Brent Wood
> ________________________________
> From: David Haynes II <dahaynes at umn.edu>
> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Sent: Thursday, February 19, 2015 5:15 AM
> Subject: Re: [postgis-devel] shp2pgsql
> Nothing published yet, but we are developing a working document.
> Mostly we are testing this viability of spatial datasets and if a platform
> supports complex spatial queries (i.e. vector raster overlay distributed
> across a series of nodes). In addition we plan to conducting testing on tile
> size and raster density in relation to these complex queries.
> On Wed, Feb 18, 2015 at 9:48 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> I find this research type very interesting.
> Do you have something published about your experiment and test of various
> cluster-postgres flavours?
> About loading geometry into your cluster, you may prefer to change OGR,
> which can read a lot more formats
> (and is however slower than postgis shp2pgsql).
> Cheers,
> Rémi-C
> 2015-02-18 16:37 GMT+01:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> On 2/18/2015 10:21 AM, David Haynes II wrote:
> Hello,
> I am working on a project that conducts high performance spatial
> analysis using postgresql and PostGIS. We have been searching for
> platforms that allow PostGIS to run in parallel. We have evaluated
> Postgres-xc and postgres-xl and determined that they do not meet our use
> case. Currently, I am evaluating CitusDB, but there seem to be some
> obstacles there as well. However, we are working on developing our own
> platform using Stado, which is dervied from GridSQL.
> We have had some initial results that look pretty promising and we are
> looking to modify the source code of the shp2pgsql to work with our new
> platform. If someone could provide the location of the code we would
> greatly appreciate it. Currently we are creating are geometries using
> the ST_GeomFromTxt function.
> http://trac.osgeo.org/postgis/browser/trunk/loader
> postgis-devel mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> David Haynes, Ph.D.
> Research Associate Terra Populus
> Minnesota Population Center
> www.terrapop.org
