[postgis-devel] please review my assumption about segmentize and bbox
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Nov 12 20:01:59 PST 2016
Thanks, that is good to know.
-Steve
On 11/12/2016 8:24 PM, Paul Ramsey wrote:
> For both curves and for geography the bounding box/volume is calculated
> to take in the whole arc, even if the furthest extent of the arc does
> not happen to have any vertices on it. So, if you density the
> arc/great-circle, the box should not need to be re-calculated, since any
> new vertices will be added into the existing arc.
> On Sat, Nov 12, 2016 at 6:35 AM, Sandro Santilli <strk at kbt.io
> <mailto:strk at kbt.io>> wrote:
> On Sat, Nov 12, 2016 at 09:25:58AM -0500, Stephen Woodbridge wrote:
> > What about curved geometries? like arc segments. Is the BBOX defined based
> > on the true arc BBOX or the segmentized arc BBOX, if the later then changing
> > the segmentation of an arc could in theory change hte BBOX.
> Yep, this is similar to the point raised by Darafei (geography).
> To be honest I don't know how BBOX is computed for curves though.
> Once again though, topology does not support curves (nor geographies).
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
> <http://lists.osgeo.org/mailman/listinfo/postgis-devel>
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
