[postgis-devel] A snap for PostGis
Julia Palandri julia.palandri at canonical.com
Tue Nov 29 03:44:42 PST 2016
Hi Paul!
Thanks for your questions! I'll try to address them one by one:
On Mon, Nov 28, 2016 at 7:20 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Hi Julia,
> I have a number of questions, none of which really bear on us actually
> doing the work to make a snap :)
> - how is this different from other Ubuntu/Canonical initiatives like Juju
> and Charms?
Well, Juju is an orchestration service. It's focused rather in the "forest"
than in the "tree" :)
Snaps don't know about the rest of the nodes in your cluster, for example,
while Juju (or other orchestration software) will, and could tell your db
snap in a node it can replicate to other nodes.
Juju and Snaps are not bound together, you can use one without the other.
> - is this a Canonical/Linux flavour of Docker (lighter, better,
> Linux-only)?
Hm, well, snaps are 'smaller' than docker: it allows (rather, constrains)
app confinement, but doesn't provide OS confinement.
You can, however, have them interact: you can use snaps inside Docker
containers. Or you could use Ubuntu Core and the Docker snap to have a
really secure host for your Docker containers.
> - PostGIS is a run-time loadable DLL for PgSQL. Can the PgSQL snap really
> reach into another snap (PostGIS) and load the .so from there? Seems like
> we rather heavily break the isolation model.
If PostGIS is mostly used with a dedicated Postgres, it might be a good
idea to bundle Postgres in the PostGIS snap.
If instead PostGIS is thought to work on any preinstalled postgres database
(snap or not), we'd probably be talking about a new snap "interface" that
would let your PostGIS snap copy its .so outside of its confinement, into
the Postgres directory.
Visually, If the confinement around each snap could be a box, "interfaces"
change the shape of that box.
> - How does the PgSQL snap deal with major version updates? It's all very
> well going from 9.4.1 to 9.4.2, but 9.4 to 9.5 can be a huge deal and is
> fraught with dangers. Just run pg_upgrade and cross your fingers? We'd have
> to run SQL directly on the database, and potentially with quite high
> privilege (foreach db with postgis, run 'alter extension postgis update to
At the moment there are different snaps for each major version available
(snap find postgres shows this), all of these in the stable channel. We
are, however, working towards having smarter channels. Right now there is
edge, which you can update with every commit to trunk. There's also beta,
candidate, and of course stable.
We're aiming at having 9.6/stable, 9.6/candidate, 9.6/beta, 9.6/edge,
9.5/stable, 9.5/candidate, and so on, and also a "magic" latest family:
latest/edge, latest/beta, etc. latest'stable would be the version you get
when you ask the system to install any snap, without manually specifying
the major version and flavour.
Hope to have helped!
Best,
> Thanks!
> P
> On Mon, Nov 28, 2016 at 9:08 AM, Julia Palandri <
> julia.palandri at canonical.com> wrote:
> Hi everyone!
> I’m Julia. I work at Canonical on the engineering team building Ubuntu and
> Snapcraft [1].
> We’re working on snaps, a platform to enable ISVs to address a
> considerably wider audience while retaining full control over updates.
> Snaps are “write-once, run on many distro versions”, including both Ubuntu
> 14.04, 16.04, and many others (http://snapcraft.io/docs/core/install) -
> they make dependency problems a thing of the past, and offer early adopters
> the possibility to try new features as soon as they’re committed to trunk,
> all with minimum effort from your side (the hosting on our side is
> complimentary ;)).
> Snaps help also to handle upgrades: they’re done transparently for users,
> which is convenient for them and for you (no users stuck in a super old
> version no longer supported, no work need to be done by them). And, in case
> anything bad happens (because… bad things sometimes happen :D) there will
> always be the chance of rollback available.
> I first wrote to a member of the PSC, who asked me to write here instead.
> I was wondering if you’d be willing to discuss some ideas on how we can
> help deliver PostGis to many more users?
> Cheers,
> [1] http://snapcraft.io/
> Julia
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20161129/23fbf046/attachment.html>
