[postgis-devel] A snap for PostGis
Paul Ramsey pramsey at cleverelephant.ca
Mon Nov 28 10:20:38 PST 2016
Hi Julia,
I have a number of questions, none of which really bear on us actually
doing the work to make a snap :)
- how is this different from other Ubuntu/Canonical initiatives like Juju
and Charms?
- is this a Canonical/Linux flavour of Docker (lighter, better, Linux-only)?
- PostGIS is a run-time loadable DLL for PgSQL. Can the PgSQL snap really
reach into another snap (PostGIS) and load the .so from there? Seems like
we rather heavily break the isolation model.
- How does the PgSQL snap deal with major version updates? It's all very
well going from 9.4.1 to 9.4.2, but 9.4 to 9.5 can be a huge deal and is
fraught with dangers. Just run pg_upgrade and cross your fingers? We'd have
to run SQL directly on the database, and potentially with quite high
privilege (foreach db with postgis, run 'alter extension postgis update to
Thanks!
P
On Mon, Nov 28, 2016 at 9:08 AM, Julia Palandri <
julia.palandri at canonical.com> wrote:
> Hi everyone!
> I’m Julia. I work at Canonical on the engineering team building Ubuntu and
> Snapcraft [1].
> We’re working on snaps, a platform to enable ISVs to address a
> considerably wider audience while retaining full control over updates.
> Snaps are “write-once, run on many distro versions”, including both Ubuntu
> 14.04, 16.04, and many others (http://snapcraft.io/docs/core/install) -
> they make dependency problems a thing of the past, and offer early adopters
> the possibility to try new features as soon as they’re committed to trunk,
> all with minimum effort from your side (the hosting on our side is
> complimentary ;)).
> Snaps help also to handle upgrades: they’re done transparently for users,
> which is convenient for them and for you (no users stuck in a super old
> version no longer supported, no work need to be done by them). And, in case
> anything bad happens (because… bad things sometimes happen :D) there will
> always be the chance of rollback available.
> I first wrote to a member of the PSC, who asked me to write here instead.
> I was wondering if you’d be willing to discuss some ideas on how we can
> help deliver PostGis to many more users?
> Cheers,
> [1] http://snapcraft.io/
> Julia
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20161128/e679aca1/attachment.html>
