[postgis-devel] Docs broken for other languages
Sandro Santilli
strk at kbt.io
Sun Jan 29 14:21:21 PST 2017
On Sun, Jan 29, 2017 at 03:11:04PM -0500, Regina Obe wrote:
> > On Fri, Jan 27, 2017 at 06:03:51PM -0500, Regina Obe wrote:
> >> Did we ever setup Debbie to automatically pull from transifex. I think I had installed the client and that you might have had something in shell scripts to pull the file, but can't remember.
> > make -C doc pull-tx
> > But I'm not sure we want bots to do that automatically as after confirming the translations work (make -C doc html-localized pdf-localized) the pulled changes should be committed to the repository.
> Agreed. How about you do that? Ideally I'd like the 2.3 and 2.4 docs up to date before I do the 2.3.2 release in a couple of days.
Done in trunk:
r15300 = 8e3bbcac4e659fdbe861806bb58b90a2b7ec4e8b (refs/remotes/trunk)
I don't know how branching works (if at all) with transifex so I'm hesitant
to do it with 2.3 branch, can you try that one, having more daylight ?
> I think I can at least build some of them without issue like all the latin based languages.
make html-localized worked fine in trunk here, after pull-tx.
--strk;
