[postgis-devel] Docs broken for other languages
George Silva
georger.silva at gmail.com
Mon Jan 30 02:31:39 PST 2017
Thanks Regina.
@strk: for what I know the docs are only updated on transifex when the
changes hit the svn-trunk branch, correct?
Is there anything we can help in these proceedings?
Thanks again, to both :D.
On Sun, Jan 29, 2017 at 8:21 PM, Sandro Santilli <strk at kbt.io> wrote:
> On Sun, Jan 29, 2017 at 03:11:04PM -0500, Regina Obe wrote:
> > > On Fri, Jan 27, 2017 at 06:03:51PM -0500, Regina Obe wrote:
> > >> Did we ever setup Debbie to automatically pull from transifex. I
> think I had installed the client and that you might have had something in
> shell scripts to pull the file, but can't remember.
> > > make -C doc pull-tx
> > > But I'm not sure we want bots to do that automatically as after
> confirming the translations work (make -C doc html-localized pdf-localized)
> the pulled changes should be committed to the repository.
> > Agreed. How about you do that? Ideally I'd like the 2.3 and 2.4 docs
> up to date before I do the 2.3.2 release in a couple of days.
> Done in trunk:
> r15300 = 8e3bbcac4e659fdbe861806bb58b90a2b7ec4e8b (refs/remotes/trunk)
> I don't know how branching works (if at all) with transifex so I'm hesitant
> to do it with 2.3 branch, can you try that one, having more daylight ?
> > I think I can at least build some of them without issue like all the
> latin based languages.
> make html-localized worked fine in trunk here, after pull-tx.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
George R. C. Silva
Sigma Geosistemas LTDA
http://www.sigmageosistemas.com.br/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170130/7aafded8/attachment.html>
