[postgis-devel] Docs broken for other languages
George Silva
georger.silva at gmail.com
Mon Jan 30 13:17:44 PST 2017
Hello all.
Indeed there is an error on the translation.
I'll setup the make machinery here so se can pull and build It.
Transifex should have complained about that att the moment of translation,
not build time.
Disable the pt generation for now while I check everything?
Sorry about that.
Thanks
Em 30 de jan de 2017 7:10 PM, "Sandro Santilli" <strk at kbt.io> escreveu:
> On Mon, Jan 30, 2017 at 04:00:16PM -0500, Regina Obe wrote:
> > Strk you said they all built fine locally for you right? So I guess
> maybe we don't have something set up right on Debbie.
> Uhm, I just tried again and indeed I get the same problem as you.
> > /usr/bin/xsltproc --novalid ./xsl/postgis_aggs_mm.xml.xsl
> postgis-out.xml > postgis_aggs_mm.xml
> > installation.xml:568: parser error : Opening and ending tag mismatch:
> para line 565 and ulink
> > > para um exemplo de problema resolvido configurando com este. NOTA: que
> você n
> listitem line 564 and para
> > arregador GUI que ainda não está documentado e permanece experimental.
> </para
> Tag mismatch, this is one of those cases in which I could try to fix
> locally but then upon "make push-tx" I could override the work others
> have done between the time I pulled and the time I'll push.
> How should we deal with these cases George ?
> Contact BR translators (Last-Translator put in Cc) ?
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170130/a6b6f57c/attachment.html>
