[postgis-devel] Docs broken for other languages
George Silva
georger.silva at gmail.com
Mon Jan 30 13:31:19 PST 2017
Transifex, last time i checked counted and identified some special words,
like urls, few indicators of snippets , etc. Then, if you forgot them, it
would give a warning (you can just proceed).
I remember clearly to complaint about missing tokens.
Looks like there is only a few errors. I'll check with Poliana.
I'll see if we can resolve this by tomorrow.
Em 30 de jan de 2017 7:25 PM, "Sandro Santilli" <strk at kbt.io> escreveu:
> On Mon, Jan 30, 2017 at 07:17:44PM -0200, George Silva wrote:
> > Transifex should have complained about that att the moment of
> translation,
> > not build time.
> Does Transifex allow you to define a command to run to check translations ?
> In this case is this kind of snippet here that corrupts the text:
> eferir-se ao ticket ulink url="http://trac.osgeo.org/
> postgis/ticket/748"
> >http://trac.osgeo.org/postgis/ticket/748</ulink
> As you can see the "ulink" tag is missing the opening bracket, should be:
> eferir-se ao ticket <ulink url="http://trac.osgeo.org/
> postgis/ticket/748"
> But I dunno how could Transifex know it's an XML...
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170130/e6a6056a/attachment.html>
