[postgis-devel] extensions not building in 2.4.2?
Regina Obe
lr at pcorp.us
Thu Nov 23 17:11:28 PST 2017
They should be there. That's a mistake on our part they are not packaged.
Might have been because of our recent changes to configure in 2.4.2 to fix new autoconf issues. I think I didn't notice it because building with xsltproc will rebuild them.
I've ticketed here:
https://trac.osgeo.org/postgis/ticket/3934
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Tom van Tilburg
Sent: Thursday, November 23, 2017 4:56 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: [postgis-devel] extensions not building in 2.4.2?
Doing a fresh build on ubuntu 17.04 with:
./autogen.sh
./configure
I expect the extensions directory to be added to GNUMakefile, but it doesn't. Same procedure for 2.4.1 *does* build the extensions.
Looking into the configure.ac <http://configure.ac> , it seems to boil down to:
EXTENSIONS=""
if test \
"x$XSLTPROC" != "x" -o \
-e doc/postgis_comments.sql -a \
-e doc/raster_comments.sql;
then
if test "x$RASTER" = "xraster"; then
AC_MSG_RESULT([enabling PostgreSQL extension support...])
EXTENSIONS=extensions
AC_SUBST([EXTENSIONS])
fi
fi
This part is the same in 2.4.1 and 2.4.2 and the only thing that I can see that changes the outcome is the removal of doc/postgis_comments.sql and doc/raster_comments.sql
from the 2.4.2 distribution.
Now, since the SQL files were not supposed to be there in the first place (they have been put in .gitignore) it seems that all these years I have been building extensions illegally and free-riding on the distributed comments files (never ran into trouble with it). Is my assumption correct that the pre-2.4.2 configuration was wrong? And that I should fix my setup to build these comments files in order to get extensions back?
Best,
Tom
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20171123/cad47b1c/attachment.html>
